Pinned and Promoted Products
Purpose:
To prioritize key products in search results and ensure high-value or featured items always appear at the top.
How it Works:
  • Pinned Products:
    These remain fixed at the very top of search results whenever the rule applies.
    Ideal for spotlighting bestsellers, new arrivals, or high-margin products.
  • Promoted Products:
    These are boosted in visibility within the search results but are not fixed to the top.
    Their position may shift dynamically depending on relevance and user behavior.
Usage Guidelines:
  • Pin only a limited number of products per keyword to maintain search balance.
  • Promote complementary or related items to increase exposure without overwhelming users.
  • Regularly review pinned products to ensure they align with current campaigns or inventory status.
Example:
For the search term “headphones,” you might pin your latest model at the top while promoting accessories like cases or cables below it.
Significance:
  • Keeps strategic products consistently visible.
  • Reduces dependency on algorithmic ranking for key promotions.
  • Enhances merchandising control while maintaining natural search flow.
    • Category Display Settings
      Purpose: To control how products are visually arranged and ordered within the category page. How it Works: Display settings manage the ranking priority between pinned, promoted, and regular products. This helps you define how featured products appear ...
    • Buried and Hidden Products
      Purpose: To deprioritize or remove certain products from appearing in search results without removing them from the store entirely. How it Works: Buried Products: Remain visible but are ranked lower in search results, reducing their prominence. ...
    • Categories
      The Categories configuration under Merchandising in ConversionBox.ai allows you to manage how products appear within your store’s collection or category pages. You can pin, promote, bury, or hide products to control visibility and product order, ...
    • Search
      The Search configuration within Merchandising in ConversionBox.ai allows store owners to precisely control how products appear in search results on their Shopify storefront. Instead of relying solely on automatic ranking, this feature enables manual ...
    • Search Query Management
      Purpose: To oversee and optimize merchandising rules tied to search terms, ensuring configurations stay accurate and relevant. How it Works: The Search Query Management interface lists all active search configurations. Merchandisers can review which ...
